worcester combi
7 May 2009
Glasgow
worcester combi boiler, radiators are lukewarm, hot taps barely tepid, warning light flashing rapidly.
I had an engineer out he bled radiators and topped up the pressure, 2hrs after he left it was lukewarm again, light flashing. The pressure is sitting at 2, neither rising nor dropping. any suggestions please?
its a worcester 24si 11, the light is above the hot water dial, apparently its a fault indicatot, it flashes a number of times per second to indicate fault. the radiators were hot again couple hours ago, but then went cool again, the light stops sometimes then starts again.
You need to tell us how many times per second that the light is flashing.Most of the faults require a competent engineer to fix.Codes are in the manual.
