Hi, i've got a danesmoor 15/19 (floor) oil boiler and it is leaking from the pump (oil), boiler man is coming out next tuesday but it stinks! there are 2 allen key bolts on the front of the pump, one marked v and one marked p, the oil seems to be coming from the p bolt, can I just tighten them to reduce the leak (its hardly gushing but just weeping a bit) until the guy comes out on tuesday or is this going to damage the whole thing?
the leak seems to stop when the boiler is on, just weeps when it is off
your thoughts on what the problem is and how I could reduce the problem (apart from leaving the boiler running all the time) would be much appreciated. cheers sean.
