I think my Digistat may be broken. In auto mode, temperature is recording as 24 degrees (it is actually 18C ). So Boiler will not spark up unless I set the temperature to above 24. Currently I have target temp set at 26. Auto mode will not work at all.
Have tried changing the batteries. Have tried moving the control to a cold room. It is as though the Digistat cannot correctly interpret the room temperature. It is about 3 years old, worked perfectly until now.
These units have problems with Wifi signal. I do not think it is the signal - seems to be the Digistat is not correctly measuring the right temperature.
