Worcester Greenstar 24Ri PCB Replacement of
8 Dec 2023
Although not as experienced as some of you, I am fully qualifed (with 4 year appenticeship) gas engineer and been working full time in the field for several years.
Any advice on removal and replacement of Worcester Greenstar 24Ri PCB (my first time doing one of these!)
Do they just pop out relatively easily, or are they buggers. Any optimization required?
Any advice would be very helpful. Thanks
Tony
If you can get yourself in the combustion chamber side of the forum, you should be able to pick up all the hints and tips you want. I haven’t worked on that particular model, but shouldn’t be relatively easy.
