- Joined
- 6 Mar 2017
- Messages
- 5
- Reaction score
- 0
- Country
Hi all,
I had a new boiler (Worcester Greenstar 24RI) fitted about 5 years ago when I had an extension built which replaced on old Potterton boiler. The old Programmer was moved across which was a Honeywell ST6400.
I bought a few years back a Honeywell Sundial Pack 2 which has the added benefit of a Wireless room stat which I have not had before and just used programmed on/off times only. I chose the Sundial because it was a direct replacement for the 6400 and meant no need to call out an electrician or plumber because the back plate wiring would stay the same. for some reason I never got around to swapping out and finally did a couple of weeks ago but I think this "No wring changes needed" is a red herring.
The old system under the ST6400 worked seamlessly and included a pump overrun feature for when the heating turned off. What I have noticed is when the room stat turns off the boiler when the room temperature has been reached you hear a pressure noise which lasts for a few seconds and upon investigation i believe its due to the pump overrun not working when the stat turns off the boiler.
I have trawled the internet and there is mention of this being an easy fix with a single wire from the boiler but what I would like to ask is:
1. Is this the case and an easy competent DIYer fix, switch of electric and run a single bypass wire or something like that? or much more complex?
2. If not and I will go down the electrician route but want to check based on experience if the Sundial setup is the best product for a Worcester Boiler? Is there a better solution (product) which enables me to have a wireless room stat? even if that means spending a bit more and getting a new product and re-wire the whole thing? Im not bothered with these internet based controllers as don't see the point in paying a subscription to control your heating.
Thanks in Advance
Thanks in Advance
