- Joined
- 20 Feb 2022
- Messages
- 3
- Reaction score
- 1
- Country
Ok so I'll try keep this brief.
DHW is warm but never hot enough for a bath.
When you increase flow from tap, the boiler ramps up but water is still luke warm.
I've cleaned the primary exchanger with a good flush, nothing really came out, was quite clear.
I've changed the secondary plate exchanger for a new one, changed the entire flow sensor and housing as was leaking.
Changed DHW thermistor and cleaned the diverter valve. Water does not leak into CH when running hot water.
What am I missing?
It's almost like the flow to heat ratio is wrong, as the boiler increases output when the tap flow is increased but just not quite enough. It used to run perfect.
Amy ideas? Many thanks in advance.
Midge
What am I missing?
Midge
