The boiler and all pipework rads etc are 5 years old , the boiler is needing to be pressureised three times a day , there are no leaks on any rads , valves etc . The expansion pipe is not dripping at all . It seems to lose pressure when the hot tap is being run which would point me at the dhw heat exchanger , worcester tech help think it will be the main heat exchanger is faulty and the water is coming out of the condensate pipe , how hot should the condensate water be . They say it wont be the dhw heat exchanger because then it would overpressurise. Any advice gratefully recieved as I dont want to get the main heat exchanger changed when the part costs nearly £500 unless I am certain it is that part . Cheers
