- Joined
- 27 Feb 2018
- Messages
- 7
- Reaction score
- 0
- Country
Hi
I have the above oil fired Central Heat/Water heating system. I get it serviced each year but it is not due again for another 6 months so hoped someone could give some help on the following.
I am an Engineer so capable to handle moderate DIY jobs and have fixed problems on the boiler before but not sure where to look on this one.
I have a dual channel controller on the system - a proper Worcester one.
With the Central Heating set to off, When I turn the Hot Water to ON the light comes on but no relay clicks/noises and certainly no hot water heating etc.
If I then turn the Central Heating to ON the light also comes on and again no clicks/noises.
It is only when both Hot Water set to ON and Central Heating set to ON and then I turn the Central Heating to OFF (light off) that the system fires up and starts heating water. To stop the water heating I have to turn the Hot Water to OFF. Obviously when up to temp it might stop on its own. This is the only way I can get it to fire up.
Temp thermostats on front of unit are up high as is the room stat so heating should be called for.
I had the same problem (I cant remember exact symptoms) when the chap serviced the system and he said the Controller was faulty and would cost £150+. So I have got a non Worcester controller and wired that up and get exactly the same results. So I think the Controller is not at fault.
Could it be the Control Board that houses the relays that is fault? Dodgy relay?
If someone could give me a few ideas where to look that would be great as don't really want to pay for the Engineer to come back and am sure if I call him he wont remember the fault in detail. I have searched the forums on this but it is difficult to search on such a strange symptom.
Please be gentle... and many thanks in advance.
