Just moved into our new house and for the first time ever have an oil fired central heating system. Had a few problems initially for the first couple of weeks. Got it serviced and seems better, but still not sure about one thing.
The hot water and heating seem to be operating as they should. I have a centaurstat wired in hallway and set times to suit our needs. But have noticed that if its set for an off period throughout the day it will fire up and put hot water through to the rads. It seems to be doing this regularly throughout the day for short periods, even if I select off on stat it will still do it. So needlessly using oil when I dont need it on.
Any one have an idea if this is normal, have always had gas combis before and never had this happen with them.
One other thing, because the hallway is fairly small with a rad in there, it soon warms up the hall and then switchs off the heating but other living areas are still a bit cooler. Thought of maybe looking at fitting a wireless room stat in the living room, so we can get living room up to desired temp as thats out main room.
Mark
Mark
