I have a worcester heatslave combi boiler-heating will come on no probs-but when you use the dhw heating then goes cold i have to turn the heating off then back on again to get it to work..I have had a good read on here and taken the cover off the honeywell valve-when heating is turned on the arm on the valve turns to the left then stops in that position-when hot tap is opened or the hot water on the timer is advanced to the on position, valve returns to start position-after a short while boiler then starts up for the heating but valve does not move unless heating turned off then back on again,also the dhw isnt that hot which prob is a seperate problem.
Has anybody come across this prob before?Im guessing it might be be either the pcb not sending the signal to valve or the timer not sending signal to pcb after the dhw has been used??
