I wonder if anyone here can give me any advice. I recently moved to a house with what appears to be a pretty old Worcester heatslave 9.24 (GC 47.311.02 if that's of any use). It was fairly noisy from the start, but worked OK. Now it makes a seriously bad noise when running the hot water for extended periods of time (e.g. when running a bath) and the other day it cut out (and the pilot light went out). I have been told that this was probably due to overheating.
I have successfully relit the pilot light and for now am avoiding using the hot water too much (the heating ran fine for 4 or 5 hours the other night - except for the noise which I suspect is due to the pump being on its last legs). Has anyone got any idea what the problem might be? Would replacing the pump have any effect, or are more serious remedies required? Any help you could offer would be most appreciated.
Regards,
Leigh
Regards,
Leigh
