M
MarkGibson
Following on from my earlier question.
I am still having trouble with my hot water from the above machine.
So I have at least ruled out the water temp sensor (on the Heat Ex outlet)
So I have been doing more thinking!! and have come up with the following possibly flawed reasons for still not working.
The gas valve (which I know next to nothing about) has 4 wires, I guessed that 2 of these are for the spark and the other 2 are to control the gas to the valve? Now i guess this means my valve cant be faulty due to the fact the central heating is working, and the electronics must control the valve on the central heating side of things in a similar fashion to the hot water side. i.e regulating the flow etc. (also the above should also rule out the electronics etc being faulty??)
It cant be my pump overrun thermostat because that side of things seems to be working correctly.
Therefore I have come to the conclusion that the over heat thermostat may possibly be broken or sending the wrong signal back to the valve? (next to the pump overrun stat) and causing my boiler to cut off prematurely?
Any help from any of you guys would be greatly appreciated.
Mark
Mark
