I had a problem with water leaking out of the Automatic Air Vent. Skip forward 2 nightmare days or leaks at the air vent , at then at the drain cock, and the system is now refilled and not leaking, however the pilot won't stay alight.
When I drained down the system I only vented the first upstairs radiator closest to the boiler.
First time I restarted the system the pilot did light and stayed lit. Boiler fired up for domestic hot water and was heating fine. Then I switched on the CH and went off to check for air in the radiators. A few mins later when I came back to the boiler the gas/pilot was out and radiators had not yet heated up.
Going through the fault finding in the manual...
Pilot light is a good big flame when holding in the Gas Control Knob but goes out when release the Gas Control Knob.
It then says to
"Check E.C.O. connections at the thermocouple and gas valve following procedure 5 in the multimeter handbook. Minimum closed circuit voltage 8mV. Does Pilot stay alight?
if NO then
Change Overheat thermostat"
There are a number of things about this I find confusing and have questions.
1/ What does E.C.O stand for?
2/ How do I check this thermocouple is producing minimum 8mV via procedure 5 or otherwise? (I do have a multimeter)
3/ Would I be correct to assume that if the thermocouple is producing less than 8mV then I relace the thermocouple, otherwise I replace the Overheat thermostat aka Boiler Limit Thermostat?
Very grateful for any help you can provide.
Hopefully,
Malcolm
It then says to
if NO then
Hopefully,
Malcolm
