I have a Worcester 3.5 Highflow which when calling for heat the boiler does not fire up. However when I manually open the motorised valve the boiler fires up and the radiators seem to heat up ok. When I then return the valve back to the normal closed position after a few minutes the boiler switches off - even though it is still calling for heat.
Any suggestions on a possible cause and remedy would be VERY much appreciated.
Many Thanks
Mack
Many Thanks
Mack
