Guys,
Drained the CH system, replaced expansion vessel and currently on Sentinel x400 since 1.5 weeks ...but notice DHW water burner is cutting out time to time when on constant hot water demand! think should remain constant and so water temp fluctuate bit. More noticeable when on shower, not major issue at kitchen tap.
That may be its due to the temperature sensor or the DHW thermo stat/dial?
Where is the DHW temp sensor located; is that the one in front/left of storage tank with 2 pink wires? if so what should be the resistance across? Is this direct screwed to tank or thermowell and does not need tank emptied?
and also anyway to test thermostat too - check resistance or voltage etc?
Cheers
Cheers
