Worcester Mechanical timer and trv questions
17 Feb 2008
Fife
1) Our new worcester 28i junior has a twin channel dt20 digital timer however our old 28i junior (previous property) had a mt10 mechanical timer which we much prefered as we dont work set hours monday - friday and it was easy to flick the 15 minute incrament switches. I have found the mt10 mechanical one for 35 notes, is this compatibl with the nw style boiler and is it easy for the diyer.
2) I have read that this boiler has an automatic bypass, does this mean that it is safe to add trv's to every room?
Pippo
old time clocks are generally compatable with modern boilers sure, but if your not sure what to do id reccomend asking a electritian to instal it for you, shouldn't cost much.
And even though it has an automatic bypass i would leave either the hall or landing radiator without a TRV for circulation.
Nope you still need one without a trv and this should be where your room stat is
DT20 just pops out and the 10 clips straight back in fits with a little push in electrical connection 2 min job
need to replace a mt 10 timer on a greenstar 28i - is it easy
how do you get cover off ?
