worcester 240 will not turn off when heating is switched on,rads will continue to run until I switch power off at spur, thermostat has been checked and passed ok.Have not got this problem when running hot water for shower etc. Thank's.[/img]
You need to have some fault finding carried out, principally looking at electrical side of controls and boiler. Unless you feel confident about trying this yourself (good basic knowledge of electricity needed) you must get in a good heating engineer.
not sure I get the problem, when you say the rads continue to run when the heating is on do you mean they are getting too hot or they are continuing to heat after the programmer should turn them off?
