Today i decided that the upstairs radiators in my (rented) house had been cold for long enough, so bled them..... now the pressure in my 28cdi is 0..... my landlord has the key thing for the expansion tank, which i now realise i need to use to top it up.... (and probably rebleed as i'm guessing air has been sucked in).....
when i turn the boiler on, it makes a noise like it is filling with water, and i can't remember this happening before. there are also some other rattles every so often, which i don't remember either....
i can't get the key thing for a while, but with the forthcoming cold weather am loathed to do without heating.... am i ok to risk running with zero pressure? are the startup noises (semi?) normal? is there any other way to repressure the system?
thanks for your help
chris
chris
