Hi guys,
Sorry for the length of this post, but I've just had a W-B 440CDI boiler installed, on paper and from reviews it seemed just the job to heat and provide hot water for my 4 bed detached bungalow.
The guy who installed seemed to do all the right stuff, like flushing the system etc and followed the installation instructions.
FYI we have a static water pressure of 2.5B and a flow of 22l per minute.
Water temp control on boiler is set to 4
Problem is the water temp at a hot water tap near the boiler cycles between 36C and 62C - even though the flow rate is only 7l per minute.
It does this within a couple of minutes of turning the tap on ie after about 15l - no where near the 51l or 20l / per minute flow rating.
I also notice the temp on the boiler goes as high as 112 !
There's also gurgling and bubbling noises coming from the boiler.
I suspect the heat store is not filling correctly.
As a consequence even the show goes from luke warm to scalding hot.
Any ideas or suggestions ?
Thanks Tim
Thanks Tim
