I have a new kitchen extension and I need to run a new water supply pipe to it, across my driveway and front garden, connecting to the existing 1/2" (not 15mm) copper pipe passing beneath a retaining garden wall adjacent to the pavement (where my water meter is situated).
I'm intending to use a single length of 25mm MDPE pipe, terminating in the kitchen with a stopcock, but I have a couple of questions:
I'll be digging a new trench across the garden and driveway. The existing supply pipe is not very deep in the ground. It runs a short distance across my front lawn from behind a retaining wall, and while it is about 450mm under the lawn, it is about 50mm ABOVE the level of the driveway it needs to cross. What is a sensible depth to dig a trench (ie how far beneath the finished surface) should the pipe run in the ground?
Once I have excavated and run the pipe, what would be the best type of fitting to connect new to old? I looked at the range of stuff in a local DIY shed, but they only do push-fit 25mm/15mm connectors, and I don't think I'd get a good reliable connection with 1/2" pipe, and doubt that such a fitting would be suitable for burying, anyway?
Will the pipe require any particular protection before back-filling the trench? I was wondering whether to use 10mm gravel, as I did for the underground drainage pipework, before reusing and compacting the excavated material.
