I have bought a house and none of the doors close properly.
I could buy new doors but old doors are solid wood and new doors these days are hollow. There is also the added hassle of sizing them with an angle grinder.
The hinges were all painted over (two hinges per door ) and painstakingly I have replaced the hinges and screws. I have used these hinges :
https://www.screwfix.com/p/zinc-plated-steel-loose-pin-hinges-76-x-29mm-2-pack/41763
and these screws :
https://www.toolstation.com/twinthread-countersunk-pozi-screw/p87435
The doors still don't close! What do I do at this point ?
Should I use longer screws ( I have these at home too - https://www.toolstation.com/twinthread-countersunk-pozi-screw/p11692 ) ; is there a way to screw the hinges - e.g. the top screw stays loose and the rest need to be tightened ; should I close the old holes with toothpicks and make new holes ; should I drill pilot holes ?
The surface is painted but uneven. Should I use wood filler on top to smooth these minor bumps out and then repaint ?
Thanks.
and these screws :
Thanks.
