Hi we are looking to heat our workshop so we bought a oil fired boiler and are looking for some advice on fitting the vented system please .
boiler is worcester greenstar ii he 12/22
we have 3 double rads and a hot water cyl to install. cylinder in out 22mm copper, rads are 10mm micro plastic in out .
we have 2 header tanks one large and one small for c/h + h/w these will be installed in the loft area of the workshop and supplied by 15mm copper pipe
the boiler will obviously be on the floor level of the shop
Questions are :
The hot water cylinder can this be on the same level as header tanks or must it be below ?
Do we need to install mortised valve if we want constant hot water and constant heating ?
dose the c/h pump have to be positioned in any specific location ? ie can I fit it on supply just above boiler ?
Tommy
Questions are :
Tommy
