We have just had the blockwork completed on a workshop built from 100mm wide 7N concrete blocks. The gable ends have been built as well and the peak is 1m above the wall line. The workshop is 9m long and 5m wide. The joists will need to run across the 5m wall. We plan to put the roof on ourselves and after reading various websites we have some questions.
1. What size timbers do we fit on top of the wall to mount the joist on?
2. Do we fit a damp proof strip under these timbers?
3. Are these timbers screwed directly to the wall all are they floated on a bed of mortar?
4. What size timbers do we need to use to construct the roof frame assuming the roof will be fitted with concrete tiles.
5. how far apart should we fix the roof trusses?
Thanks in advance for your help.
