worktop jig
26 Nov 2009
London
I HAVE AN OUT OF SQUARE KITCHEN MY PROBLEM IS IF I WANTED TO USE A WORKTOP JIG IS THERE A LIMIT TO THE AMOUNT THE TOP CAN BE CUT OUT OF SQUARE USING THE JIG THANKYOU
I have just done a kitchen and utility where the worktop joint was out of square by 10mm(U shaped kitchen)
I had a successful joint on both counts, after cutting both joints (male & female) 5mm off the original Jig.
It is possible to do almost anything regarding this subject but be sure to sit down and think through what it will mean to other things if the joint is cut out of square.
Andy
