hello - please can someone help with cental heating system refill problem?
Basically I assumed the drain on the bottom of the boiler would drain the system. Some water did come out but in rather a weak fashion. Anyway I then drained the system using the lowest radiator. Then I removed some unwanted radiators and refilled the system. I have bled every radiator and I believe the system is now filled. My worry is that the boiler has not filled...
The drain at the bottom of the boiler is dry. I believe water is in the two pipes that go to the boiler since the radiators removed linked to these pipes - and as I have temporary push fit stop ends on them I can verify that water comes out with gusto!
Many thanks
Many thanks
