Worst shower experience
28 Nov 2009
Hi all
I hate me new shower.
It's a triton cara and the issue is that the flow is slow. I spoke to triton and they say that the 4 litres per min on a nice warm temperature is normal. But it feels like a bad shower experience every morning.
We have a combi boiler. Not gravity fed water supply so I'm told a power shower is not an option.
Does anybody have any advice as a alternative?
Eg buy a different make/model. I'm thinking the obvious answer is to rip it out and connect straight to our hot and cold supply ( the shower is over the bath). But before I do that I'd really appreciate some suggestions.
Thanks guys !
make/model of combi would help ;)
you would also need to know your mains water flow rate and pressure
post back info :idea:
4 litres a minute gives a rather poor shower experiance, however is enough to get clean under ......just.
But think of the money you are saving on electricity and water. Bill Oddie will be proud of you!
Your combi will deliver at least twice that flow rate, and could deliver many times that rate depending on boiler heat input and water main pressure.
It's a Worcester greenstar cdi. Brand new.
Water pressure into the house is 5 bars.
Thanks for the quick response!
what kilowatt size of CDi ;)
check your flowrate by running your kitchen cold tap into a 10 litre bucket and time it
ie fills 10 litres in 30 secs = 20 litres per minute
Sorry. I'm not sure where to check for the wattage. Buts Its a 27cdi
the flow is just over 20 litres per min
ok bengasman will be on later and will give you exact flow delivery for the 27 CDi, my guess it will be round about 11-12 litres per min
your incoming mains is good
i would plumb in an thermostatic shower from the hot and cold
you will see a vastly increased shower ;)
