Hi All,
Looking for some opinions/advice please. I have a standard semi-detached 1930 house which has cavity walls. At the moment these cavities aren't filled, but I am going to be getting this done soon.
Bearing this in mind, is it still worth taking down the old plaster on the internal side of the walls and replacing with gyproc thermal boards 27mm. I can't go with any thicker boards than this because then it will be sticking out over the inner stringer of the stairs. At the moment I am just looking at doing the hall/stairs/landing and small box/study room, but will eventually do all the external walls when those rooms are re-done.
I should mention that there is some blown plaster on the walls already but not enough in its own right to warrant taking off completely and starting again.
Other people I have canvassed are of the opinion that all insulation is good/worth it. It's not really about the time/cost, it's whether or not it's worth doing it seeing as the cavities will be filled.
Thanks in advance.
Steve
Thanks in advance.
Steve
