- Joined
- 24 Aug 2009
- Messages
- 2,680
- Reaction score
- 282
- Country
Good Morning Ladies and Gents, hope you can help me with this.
I'm renovating an old barn and have just taken down an old floor that was only used as an intermediate level for storage. I mention that to explain that the planks are simply rough cut treees i.e. just sent once through the mill, so they have two flat faces and the edges untouched.
I would very much like to use some of these as cladding in some of my rooms but the planks are all too thick at the moment (50 - 70 mm approx ) width varies from 150 - 220 mm.
Wood is dry pine, about 150 years old, so cut in the Alps when it used to be a lot colder, so a bit more dense than would be normal now.
The only way I can speculate that I could make this usable is passing it through a band-saw, but I have no idea if this is feasible technicallly and financially.
Technically because I don't know what power I would need and if I could get the power and height of cut needed from a cheap unit.
Financially because I have emphasized "cheap. I only have about 50 -60 boards to cut and no real use for a band saw after that so do not wish to invest in quality that will then sit and gather dust.
Since the effect sought is "rustic" it won't matter at all about a bit of waviness or whatever just so I can cut to approx 22 mm thick.
I don't know if blade-breakage will be a major problem with this kind of free-hand operation, but imagine it could be.
I look forward to receiving your comments and suggestions.
Thank you.
Thank you.
