The house has a WB Greenstar 38CDi combi, which means I can't have a power shower. The electric shower is a Gainsborough 10.5se.
Whilst I like the fact that it heats up relatively quickly, I hate the way the thermal "protection" works. If someone uses a tap downstairs eg to wash dishes, the feed to the shower drops a little, there's too much hot water coming out (so it scalds) and about two minutes later (probably only 20 seconds or so), the temperature of the water drops so it's cool. You then try and turn the temp up so it's a bit warmer and then it's too hot once the downstairs tap is off.
I don't mind cool water but I hate the water when it gets scaldingly hot, and the pressure is a bit rubbish. Which electric shower should I go for?
