Would this be a suitable Cooker Switch?
I understand that it may seem 'over the top' but, can you tell us what the cable size is, and the length of run + installation method ?
Although your cooker has a current rating of @12A, we need to know these details really, to be correct ;) :LOL:
It sounds like you could possibly replace the 32A mcb with a 16A mcb, and then the switch you mention would be ok.
Regards,
Ed.
Ok, now the cable from the CU is 10mm the length of run is approximately 9 - 10 metres.
The cable from the present switch (45A) to the outlet is 6mm and is about 1m in length.
The only reason I want to put this switch in is because the Wife wants that chrome effect and that range don't do a 32 or 45A DP switch that will fit into a single back box. (All my tiling is done now and now she decides she wants chrome and not white) :evil:
Thank for your help
Hi JohnD,
Sorry my terminology is wrong, its an Oven, your right I have a Gas Hob, The Oven is a twin Oven/Grill.
Hello Dave,
Replacing the mcb from 32A to a 16A will 'allow' you this siwtch.
Either that, or replace the wife !! :LOL: :LOL:
Hope this helps
Ed
