We are in the process of buying a 1960s house which has a flat roof (always said I would never buy anything with a flat roof but the area we want to be in is nearly all flat roofs – and we love the house!) Anyway, we knew it needed what we thought was just cosmetic work and we made our offer based on this but we had a homebuyer survey done which basically said the roof hasn’t been touched for about 30 years (an old couple had lived there since the 60s) and it will need replacing.
I will put in a couple of photos – as you can see there is pooling and the roof terrace at the back gets flooded when it rains.
View media item 71478 View media item 71479
The damp on the ceilings is directly below the roof terrace but the surveyor didn’t pick up any damp under the main part of the roof (although he hadn’t picked up the damp under the terrace - we only noticed that after it had been raining!) The surveyor also picked up some damp in the back downstairs bathroom but didn’t suggest a cause and we can’t see any visible signs.
View media item 71480 View media item 71481 View media item 71482
There is also damp on the front and back walls caused by run-off from the roof.
View media item 71483 View media item 71484
We are getting a roofer to have a look and give us a quote (we obviously want a serious reduction before we even consider continuing with the sale) but I just wanted to get some advice from anyone who has experienced similar problems. I guess the best scenario is that once the roof has been replaced the damp inside and on the outside walls will dry out and it won’t have caused any other problems. How likely is that or is the consensus that it is likely to be more serious than that? We have noticed damage to a couple of bricks at the back but we can’t see any serious damage to the bricks elsewhere.
View media item 71485
How likely is it that water is running into the cavity wall? What kind of damage could that cause? If the damp downstairs is also caused by the roof how serious could that be?
I know all this would probably be answered with a full structural survey but we really don’t want to spend any more money on surveys etc. as we are already seriously considering pulling out. Would really appreciate any advice or suggestions as I’m a little concerned we could be buying a money pit with problems continuing to appear years down the line.
Thanks.
Jon.
Thanks.
Jon.
