I had the mains pipe entering my flat (through the kitchen floorboards) burst last night. Rather, it was the collar on a T-joint, which split. All 3 seals in the T-joint were already split, it later transpired. Torrential flow from the mains ensued, which although only caused mild flooding in our kitchen, led to the false ceiling in the flat below, to cave in, and further leakage into the basement flat beneath that.
After we shut down the building stopcock and the emergency plumber arrived to repair the rupture, he told me that the pipes bringing the mains supply - 25mm polypropylene - are totally inappropriate for that job, and it should be 22mm copper, as with the rest of the pipes in the house. In fact, apparently this contravenes building/ water regulations.
Is this true? Even if there isn't a specific regulation specifying the type of pipe required, aren't these pipes inadequate for bringing a mains supply into a household? They certainly seem so. I need to get the landlord to replace the pipes entirely before they rupture again, and any regulations/guidelines/ bye-laws to support my case would be welcome. Cheers
