Hope someone can help.
I bought a blackhole airvent 127mm that i wanted to fit once i had knocked a hole through the wall because i had fitted a log burner.
Asked my plumber mate if he had a core drill for the job which he kindly lent me.
After spending some time drilliing the hole ( & much mess) I then went to fit the new black hole air vent only to find that the core drill bit that i used had drilled the hole too small - 100mm diameter.
Thus realising that my mate obviously uses his 100mm for soil stacks & the like.
SO, problem is, if i get hold of the right sized core drill, how can i knock the hole out bigger? as the normal masonary drill but in the middle of the core drill will have nothing to purchase on!
In the meantime i have stuck a vent over the inside & outside wall until i can drill the hole bigger to acomodate the 127mm blackhole air vent.
thanks in advance
thanks in advance
