Just had a number of radiators fitted and all but one have the "bleed valves" the opposite end to the water inlet valve. However one radiator appears to have been fitted the wrong way around and the bleed valve is the same end as the inlet pipe (directly above).
Does this matter? Will it effect bleeding the radiators (they are part of a central system so they get quite a few air bubbles in them). Any comments/advice welcime.
