Please clear up something for me. The above mentioned RCD has a 30mA short circuit current - right, and the 80 means that it can withstand a maximum of 80A - right? So how can u use this in a domestic installation whereyou normally use 2.5mm at the most.
I am led to believe there will come a time when someone comes along and connects too many appliances on the same circuit, then you gonna have some fried wires?
My thinking is that the max. size mcb on a domestic installation is normally around 32A, so why the need for a RCD with 80A Imax, surely you cold use 16A RCD 30mA?
PLease help, so confused.[/b]
