Help, I fitted a new radiator,
drained the system down and then fitted new radiator.
Refilled the system and got pressure in rads with some persistants
trouble is now when I turn the boiler on i hear gurgiling(made me think
air) bleed all rads, pump, bibs on tank and boiler. Got no where else I can see to bleed.
The gurgiling is followed by kettling, some loud knocks and the boiler cuts out. I am so broke I can't afford a plumber.
The pump seems to be working, the pipe near the boiler is getting very hot, but not getting any heat on return feed.
What else can I look at?
It's a Worcester greenstar open system, tank in loft is fine, though feel there was a blockage when I refilled it as had to put hose in feed in loft. I had tried to fill from last rad bib valve but did not work.
Please please please help it's freezing
thanks in advance
thanks in advance
