- Joined
- 30 Jul 2015
- Messages
- 2
- Reaction score
- 0
- Country
Hello all, hopefully this is the right forum for this.
Recently moved into a new place, and I want to put up some shelves in an upstairs storage cupboard. The place was built in 1998 as part of a Housing Association estate, so I assumed it would be pretty standard construction with plasterboard walls and probably studwork behind.
Get el cheapo stud finder from B&Q, start scanning the walls. Ideally want shelves at right angles, one set on the back (party) wall and one set on the adjacent partition wall. Stud finder can't find anything meaningful on any of the walls (apart from a/c, apparently everywhere), tapping is inconclusive and fridge magnets don't respond to anything.
Next step, get out the drill and make some investigative holes. Go through the plasterboard on the party wall, and immediately hit the masonry behind- I'm guessing this means it's dot and dab, but the odd thing is that the plasterboard layer is very thick- looks like two sheets of 18mm board. Is this normal? Why would you have a double layer of pb on an internal wall?
I repeat the exercise on the partition wall- the drill keeps on going, and I expect to go into the void in the studwork but there is none- I just go straight through the wall into the adjacent room. It looks like this wall is made of solid plasterboard, and is pretty thick too, easily 3 layers of 18mm plasterboard sandwiched together. Again, is this normal? I can't find any reference to internal walls being built like this on the net. It's not like this is a tiny cupboard either, it's a good 4ft square.
So, essentially two questions
1) Are my walls normal?
2) How do I go abut fixing shelves to them?
I've been looking a specialist drywall anchors for fixing to dot-and-dab walls, but they seem like they're intended to go through a single layer of plasterboard before they fix into the masonry behind. With mine they'd need to clear almost two inches of board and air gap before the wall behind, so I'd be concerned that the long 'un-anchored' part would bend and then deform the plasterboard over time. With the partition wall I accept that it just might not be possible to put any great weight on it, but any ideas are gratefully received.
