I've got the following consumer unit, which i'd like to use as part of my extension, its a split load but with a single RCD, every circuit needs RCD protection as they're not more than 50mm deep in the walls.
I'm not sure how to add a second RCD, is it ok to just put two cables into the main switch? and then cut the bus bars to fit? I can afford to drop a couple of MCBs out to give room for the RCD, I would like to keep one MCB without RCD protection for the smoke/security alarm.
Or should I just buy one of the 17th edition consumer units with two rcds already fitted?
