Ok, I've seen a few posts on this subject but none actually seem to give an answer, (so perhaps there isn't one?)
I've done some work on my heating system, and when working around the pump / vent / cold fill area I noticed the pipes had quite a nasty buildup of rust and black sludge stuck to the insides.
Last night I drained 'some' water and added X800 (so it is just plain water and X800 in there at the moment).
The X800 says that you can use it for an hour, or longer may be required for heavy buildups.
As the effected pipework is now all nicely soldered back together, how do I know when it has been in there long enough?
Niether the product, the bottle, or the website seem to give any idea of a recommended amount of time it should remain in the system.
I had it belting round the system last night with the heating thermostat set to 30 deg C, and the hot water valve set to it's manual 'open' position, with the pump at it's highest setting, but when I left this morning I set the valve and the dhw / ch thermostats back to their normal settings so as not to boil the house.
The X800 bottle does say to circulate it with all valves open, but what does it mean by that? I've opened all the TRV's fully, but should I also open up all the lockshields fully as well? (I was concerned that doing this 'might' stop the X800 circulating through the furthest rads at all?)
I'm not sure if I should be draining it out tonight, (as I had planned), as that is 24hrs rather than the single hour they 'quote', or if leaving it in longer is beneficial?
It says it includes chemicals to protect the metalwork in the system, but I don't know if this is as 'good' as the ones in the inhibitor, or if I should be aiming to get the X800 out sooner rather than later, flush, and refill with inhibitor?
