Hi
I suspect that this problem has been running for a while but not noticed as we use alot of hot water and the days are now getting colder.
The boiler, an Apollo 30B fires only when the need for hot water. Done alot of testing to try and narrow things down but still no solution. Basic Honeywell Y System with SunVic select XL programmer.
Assume that HW and CH are both on at the programmer.
If the HW needs heating then the boiler fires up. If the HW is satified and you turn the CH roomstat to max the boiler does not fire up although the mid position valve fully opens. So if both theromstats are set to max we get HW and CH no problem. Once the HW is satisfied then we have no way of heating the house.
Any clues - I suspect a wiring fault but thought I'd ask if you had encountered a similar problem.
Does the Mid position valve send a message to the boiler to ignite when the roomstat calls for it or is this done directly.
Thanks for any input.
