hi good people
replaced motorised valve y plan
need to know where the white wire needs to connect and with what...
all diagrams i have seen seem to indicate should connect with terminal from room stat..
now this is where i become ignorant and helpless
i dont have a room stat. for heating... stats only on radiators. presently the white wire connects with the connection block independent of anything else
is this because i have no room stat??? Problem is I can only get heating to rads when push lever over to manual on motorised valve.. which means I am running hot water and central heating together.. Hot water runs independent and is fine. problem cannot get heating to work independently.
boiler is an old glow worm 80 fires up when asked by controller for hot water perfect
but not for heating
any help with the wiring would be good
but not for heating
