Hi
Recently bought and fitted the HSA 6400 for the most part. Only the sirens haven't been mounted due to lack of necessary tools. Anyway I have a few questions that you guys could help me out with.
1) Does the main white control panel ever dim, can it be made to dim after a certain period of time?
2) If I drill in the extra keypad HSA6080 will the actual pad be removable without undrilling?
3) More of a stupid question, if somebody breaks in and takes the control panel and runs off will the siren still ring?
4) Any alternative ways of installing the sirens on the wall without drilling the wall plugs and installing the siren?
5) What is the ACTUAL range of the PIR from experience?
6) Can two PIRs face each other?
7) Does a PIR get affected if in front of a lightbulb?
8 ) Can the keyfob accessory HSA6060 deactivate an activated alarm?
9) Any type of batteries that last longer in the siren?
10) With the normal non pet friendly PIR what is the minimum weight to set the PIR off?
Sorry for the multitude of questions but thanks in advance for at least taking the time to read them even if you cannot answer them. I value all input.
Thank you
Thank you
