Yale HSA 3600 entry time issue
Status
Not open for further replies.
6 Dec 2011
Sheffield
I have a Yale HSA 3600.
All set up as new with new batteries etc.
Everything works on it except the entry time.
The exit time is set to 20 seconds which works fine.
The Entry time is set to 30 seconds (also been 20 secs), and after a few seconds of entry, the control panel and alarm sound (possibly 10 seconds at most).
I have tried a few entry times, 20, 30, 60 seconds, yet the same outcome after approx 5 to 10 seconds, the system sounds.
Any ideas ??
Thanks in advance to any helpful replies.
Hi, installed my HSA6400 at the weekend and had the same problem. I had to change my door sensor from "Burglar" to the Delay setting (was it called Delay, or "Entry"?). Is i t possible you are passing a door sensor or PIR set to Burglar?
Interesting.
I don't have door magnets but I do have a lot of PIR's and they are all set to Burglar.
Maybe this is it, I will check, many thanks.
If anyone knows differently or could confirm, they great and thanks.
As above you need AT LEAST ONE ENTRY DEVICE.
All there in the book of words and if you used the search facility here.
A common misgiving with these panels it seems.
Nice one, I have now amended one of my PIR's as the ENTRY point and now the control panel gives me a count down to disarm the alarm, so part one complete.
My only issue now with the above change, every time I walk in front of this PIR whilst the alarm is off, the control panel beeps.
Now I can live with it if my house gets alarmed correctly but if this is a quick fix, then I would love to do so.
Thanks for your help so far, but this last bit would be so appreciated.
Sorry, I just found that option, thought the door chime could be only low or high, not off.
All sorted.
Many Thanks for your assistance.
Well done Alarm :D
You know if you carry on like this I might even send you a Yale proficiency badge..:)
Status
