Yale HSA6400 Control Panel - no confirmation beeps or sound
Foo
27 Aug 2012
London
This is my first post to a technical forum. I recently installed the Yale HSA6400 premium alarm system and all the devices including siren have been learnt in correctly and tested. The control unit was registering keypad presses with a tone (I first noticed this after the siren was learnt in) including all alarm confirmation beeps, entry and exit sounds. All confirmation sounds ceased to emit from the control unit even before I mounted it up. The tamper alarm on the control unit is functional so I know the internal speaker if fine. All of the alert tones are switched on in the menu system too. This morning I removed the control unit and the sound was functional for a short while after the tamper had been detected. I have switched the unit off to see if it resets the software to no avail. The siren exit and entry tone is working fine but I wanted to disable it as it makes too much noise at night when home arming. Apart from no audible alerts from the control unit the system is fully functional. Could this be a faulty unit? Any help would be greatly appreciated.
To turn off the confirm beeps from the siren do the following.
From the programming menu select devices then go down to programm siren then from the list showing select confirm beep off.
As for your keypad not beeping when you press the buttons I am stumped there..
