Hi All,
I have an odd issue with my Yale wireless alarm. Had a yellow light and warning beep, checked the logs and it said the battery was low for the back door contact sensor.
I followed the normal procedure for changing the battery:
- Into program mode
- Take cover off
- Change battery
- Replace cover, making sure the spring makes contact
- Retreat out of program mode
Upon leaving program mode, I get an instant alarm. Turning it off and checking the logs shows a tamper for the back door. I try the procedure again, checking the spring is seated OK - it's fine, and I get the same alarm/tamper code when leaving program mode again.
When I do a walk test, the sensor works fine, and beeps as it should, although I do get a flashing light on the sensor when opening the door.
I tried removing and reading the device. The tamper code disappears when I remove the sensor, but when I re-add it, and leave program mode - boom - alarm and tamper code!
Any ideas? - I'm a little stumped with this.
Thanks!
- Into program mode
- Take cover off
- Change battery
Thanks!
