Hello,
Did this question ever get resolved? I have the same issue.
I have removed the existing light fitting and wish to fit a pendant (fed up of having multiple bulbs and just want one now). On removing the existing light fitting I have discovered the following:
2 blue wires and 1 black wire going into the same block (blue one side and black the other)
3 red wires going into a 2nd block (two into one side, one into the other)
2 yellow wires going into a 3rd block
Green and yellow wire going into a 4th block
However, the new pendant only has 3 blocks (live, loop and neutral). I presume that I re-wire them as follows:
2 blue wires and black wire into neutral block keeping the black wire separate (there is already a blue wire into one of the screws in the pendant)
3 red wires into live block (though there is only one free screw - the other has a brown wire going into from the pendant)
Green and yellow one into the earth screw
Are my assumptions correct?
I am left with a block that says "loop" - is this where I should put the yellow wires?
