I have a mixer tap and yes the cold water is starting to run slowly. It seems that the cold water tap does not undo as far as the hot one. The taps are the normal 'cross' type ones. I have taken off the screw top and there is a screw under that. I have removed the screw but I cannot seem to lift the cross bit off. I cannot see a grub screw that could be holding it, is there anything I can do to get it off so that I can lift the cover and see if I can get the tap to open more?
I hope this explains things clearly.
PS Looking in my DIY book the tap seems to be a mix as it has the handle of a capstan but looks like it has the workings of a shrouded, with that screw going down through the middle.
jodevizes
jodevizes
