hi guys posted yesterday onyl to find i still have the same problem.
whats happened is ive changed a plastic two way two gang light switch to a steel one.
the difference is that the new has L1 L2 L3 INSTEAD OF L1 L2 COMMON
so wiring it just the same as the old one L1 to L1 L2 TO L2 COMMON TO L3 WITH PATCH TO L3, this hasnt worked out right.
instead of it operating two way fro two lights one in and one outside, it operates like this.
if the primary switch is off the new light switch doesnt work defeats it being two way, if the primary switch is on then it operates both the inside and outside light but..... only if the outside light is switched then what happens is the outside light comes on then turning on the inside light the outside light goes off until the inside light is turned off again.
my bruv who lives far was sparks trained and says the new switch is nto compatable for two way and needs one with a common..so i contacted teh ebay supplier who says all hes double switches are made for two way.
please advise as to yuor opinions
