hi,
I have just put in a new lighting circuit in my cellar for a conversion. I have connected to each switch the Live (from new fuse) to common neutral to term block, then switched live (L1) to light fitting and again neutral to term block....the constant live to common in the first switch i have then taken to the next switch and so on!!! Here comes the problem....i wish to two way the light at the bottom of the stairs!!!! .
The original switch upstairs is two gang two way with a piece of wire from common to common. (no others wires in switch for cellar light) The new switch (cellar) has the live in common, switched live (to light) in L1 and neutral to term block...I then have just 2 core between switches....can this be 2 wayed??
I have tried seemingly numerous combinations with no sucess...i only ever manage to be able to switch on and off at the same switch and not between the two!!!
your help would be greatly appreciated!!!
cheers
Gazza!!!
ps i cannot put any more cable in as it has now been plastered!!!
cheers
Gazza!!!
