Hello,
I have a Tristan Joy 8.5 kW electric shower.
Cold tap flow rate 12 litres/min.. So mains feed absolutely fine
Shower flow rate 4.2 litres/min (with heater fully off)
When I set the shower to normal heat (setting 2) then even on fully cold, it heats to 55+ degrees, IE completely scaling, then shuts off. This is with the shower head removed, so is not a clogged head. Even "Eco" that used to be circa 35 degrees heats to 48+
I've taken the filter out of the shower and de-limescaled it thoroughly, it looked clear to be fair, either way made no difference ...
Given that 4.2 litres/a min is the pressure out of the bottom of the shower, so through the unit, but with the heater fully off - Is the shower just shagged? Or could it be something else...
I was contemplating ordering a slightly more powerful shower. It has an isolated power supply, how do I tell what it's rated to? I'd like to get a 10.5 kW unit..
And on that, any recommendations on which unit to go for?
If I've missed any info please let me know and i'll try to respond! Thanks in advance ...
Dave
Dave
